Honda CR-V & Element 2WD & 4WD Element & CR-V
2006 ABS / VSA misbehaves - disable?
Old Apr 12, 2019 | 06:49 AM
kevinocall's Avatar
Default 2006 ABS / VSA misbehaves - disable?
Only real problem is the insanely stupid ABS / VSA system, which comes on and off whenever it feels like. I know many out there like their safety devices - I object to them. Especially when they do not allow me to turn them completely off. This is the beginning of the war against Artificial Intelligence. I have tried to disable it via fuses, which causes the entire electrical system to shut down - including emergency blinkers! And once I pulled over in rush hour traffic on the interstate, no flashers, and it was locked in PARK ! How stupid is that? I replaced the 50amp fuse (the one with 2 philips screws) while on side of the road - and Halleluja it worked again. Now it's just super-annoying because when it comes on, I have to pull over, shut/start car again and go. Anyone else had this problem? I don't want to hear about the "go to the dealer" solution. This problem is not worth $1100 to me. I should be able to disable the system. I will forge ahead and eventually find out. Otherwise, a beautiful, dark gray, no rust EX car and everything else works.
Kevin in Minneapolis.
Old Apr 12, 2019 | 07:27 AM
uDraft's Avatar
Default Re: 2006 ABS / VSA misbehaves - disable?
You could just diagnose and fix the issue. Not easy I know, but as you've discovered the sub-system is integrated in such a way that you'd need to reprogram the ECU and possibly replace some components to eliminate it.
Old Apr 12, 2019 | 07:38 AM
kevinocall's Avatar
Ugh. I know you are right. It just makes me crazy is all. Thought there might be an easier/cheaper answer out there. Thanks. K.
Old Apr 13, 2019 | 02:57 AM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
I wonder if you could use a 2002-2004 ECU? Then delete the ABS pump and run 2002-2004 brake lines... definitely not easier, but perhaps cheaper if you did the work yourself.
Old Apr 13, 2019 | 07:26 AM
kevinocall's Avatar
Interesting. Probably beyond my capabilities, but I like the idea. But if the ECU didn't work I'd be lost. Thanks! K
Old Apr 13, 2019 | 07:29 AM
kevinocall's Avatar
My other thought: Can I take the sensors out, clean them, and re-install? I'm guessing there is rust/corrosion in one or all of them. I know they will say to just replace the sensors, but they cost! Can they be "cleaned"? K
Old Apr 13, 2019 | 11:10 AM
Smackin's Avatar
5 Year Member
Loved
Community Favorite
You talking about the speed sensors? I’m not sure what type of speed sensor they use but if they’re magnets, they can collect metal shavings which would throw the readings off. I would give it a shot.
Ricorib
Suspension & Brakes
Jun 16, 2013 02:33 PM
///Apex
Jul 15, 2011 02:25 PM
DeMak
Acura TL, RL & ZDX
May 1, 2007 08:23 AM
obiora
Sep 11, 2005 10:53 AM
TOMSBLUEHONDA23
Nov 10, 2004 07:54 PM
