Replace?...or SWAP? -- D16y7 to what engine?
Old Apr 6, 2019 | 12:27 AM
soundquest's Avatar
Default Replace?...or SWAP? -- D16y7 to what engine?
My friends '97 just threw a rod -- so swap or replacement time and I am looking for good input on what would make the most sense in this scenario and why. Thanks in advance.
Old Apr 6, 2019 | 06:15 AM
Freedo_Civegra's Avatar
Default Re: Replace?...or SWAP? -- D16y7 to what engine?
It depends on what sense you’re looking at.
Upgrade? B-series engine and trans.
Financial? Replace engine only with the same model.
Old Apr 6, 2019 | 09:36 AM
soundquest's Avatar
Good answer, several more questions: Curious what upgrade would look like in terms of engine model(s) and cost. Also, how much more are JDM engines than going price of an used D16y7. Would a di6y8 upgrade require new ECU? Would it it require new trans? What would it entail? Lastly, how much would a shopncharge for labor to remove/install d series engine? Rough estimate on reasonable going rate. What are best vendors for buying said engines?
Old Apr 6, 2019 | 02:01 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Dude... you can only go UP from there. Short of an HX engine... EVERYTHING is an upgrade !!!
Old Apr 6, 2019 | 02:07 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Seriously, another "D" series will be the most economical... so a Y8 longblock and ECU will work with the transmission and accessories that you have keeping the overall cost low. Jumping up to a "B", "H", or "K" series will require changing everything... but the with greater expense comes greater reward. How much coin do you have to toss at this little adventure ???
Old Apr 6, 2019 | 05:41 PM
If the shell is empty and if I were on a budget, I’d look for an Integra engine and manual transmission combo.
jkillah29
Dec 30, 2012 12:20 PM
msinsky14
Oct 10, 2005 07:36 AM
