Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2003 v6 accord tanny swap/replacement
Old Mar 31, 2019 | 11:24 AM
Flailsafe's Avatar
Default 2003 v6 accord tanny swap/replacement
The automatic transmission on my v6 accord is toast and the recall for them isnt available in Canada. From wht ive seen a J30A4 tranny from 2003-05 accords should fit but im not 100%. My plan was to buy one cash from an auto wrecker but i dont want to walk away with a tanny that potentially doesnt fit.
Old Apr 1, 2019 | 12:59 AM
shipo's Avatar
Default Re: 2003 v6 accord tanny swap/replacement
Do yourself a favor, buy a transmission from a 2006-2007 V6 Accord with a BAYA manufacturing code, that's the best engineering build of the 5-Speed automatics which will fit your engine.
Old Jun 11, 2019 | 07:18 PM
MALL's Avatar
Is the BAYA a direct fit or is there some parts changing from the old transmission?
Old Jun 12, 2019 | 12:51 AM
shipo's Avatar
Some sensors need to be swapped over, and it is best if you buy a new torque converter.
Old Jun 12, 2019 | 06:20 AM
MALL's Avatar
My 03 already has a BAYA. Is that unusual? I suppose it could have been replaced before.
Old Jun 12, 2019 | 06:39 AM
shipo's Avatar
If your 2003 Accord has a BAYA transmission, then someone has already replace your unit; the transmission wasn't built until 2005.
Old Jun 15, 2019 | 09:21 AM
MALL's Avatar
What is the best procedure for flushing the transmission cooling system? The old transmission is still in the car. Is there a acceptable method to flush the transmission cooling system only without flushing the entire system?
Old Dec 26, 2019 | 12:59 AM
MALL's Avatar
Are you sure that the BAYA wasn't made until 2005 I found a VIN plate on the transmission, the tenth digit Is a 3...I think that means it's a 2003...and there is a sticker on the transmission that says BAYA. Am I reading the VIN code properly?
I have been looking just about everywhere for a thread that explains which components need to be swaped from the 03 to the 07. The only thing that I have figured out for sure is that the Drive Plate/flexplate will need to be replaced because the Torque converter will not bolt up to it.
2005ineedhelp
Dec 5, 2023 07:36 PM
aaronm85
Mar 18, 2013 06:08 PM
a2dadamm
Apr 17, 2012 03:03 PM
HondaGuRu
Acura TSX
Oct 18, 2003 06:06 PM
