Trunk Rust 99 Civic
Old Mar 27, 2019 | 09:21 PM
salty_ff's Avatar
Default Trunk Rust 99 Civic
Hey guys,
Looking for advice on how to deal with the rust in my trunk area, POR 15 makes a great kit for floor and trunk pans which I am considering. I also have a friend who can weld so I could cut a plate to fit/weld and cut out the current pan. My only concern is the jackpoint in the rear which is a major structural component and is a part of the trunk.
Old Apr 15, 2019 | 08:26 PM
chingpo05's Avatar
Default Re: Trunk Rust 99 Civic
minor surface rust, clean it up with some all purpose cleaner firs to see if any areas are actually affected by bad rust. wire wheel then spraypaint
Old Apr 17, 2019 | 06:36 AM
OGNAEG's Avatar
Sand and inspect, I would use the wire wheel on it with a drill. Next step up there is a sander for metal and if you need to cut patches of metal then that would be your last step literally. Once metal is on sand down, seal with primer or some rust inhibitor paint (internet search) and then repaint. Looks very minor to me but then again I have a rust bucket I am dealing with currently. Best of luck!
91EFH22
Paint and Body
20
Nov 12, 2012 04:45 PM
gramkrackers
Paint and Body
Sep 11, 2012 07:39 AM
Turbo Dan
Paint and Body
May 31, 2011 11:36 AM
mikeivb
Aug 1, 2009 01:14 PM
m R g S r
Welding / Fabrication
15
Jan 9, 2009 02:16 PM
