What part is this?
Old Mar 26, 2019 | 05:28 AM
SOLFUL's Avatar
Icon5 What part is this?
I have a leak on the side of the head coming from this part, but don't know what this part is. What is it and is there a seal for it or is it metal to metal?
Thanks!
Old Mar 26, 2019 | 05:39 PM
mk378's Avatar
Default Re: What part is this?
Is it coolant leaking out? It looks like you're pointing at the coolant temperature sensor (ECT). I think there is an o-ring seal where it screws into the head. If coolant is coming through the plastic piece on the back (not the gap where the o-ring is), the sensor itself is bad.
If it's oil, it's real common for the cam plug (the large round plastic plug at the end of the exhaust cam) to leak and have oil drip down into that area. Or the VTEC solenoid gaskets, which can be hard to spot because it may only leak (but then it leaks a lot) when VTEC is engaged.
Old Mar 26, 2019 | 09:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
This ^^^^^^. Well said mk378
Old Mar 27, 2019 | 07:04 AM
SOLFUL's Avatar
mk378, looks to be oil so.........to be on the safe side, I guess i will replace the cam plug & the solenoid gaskets at the same time.
Thank you for your help!
Silentsvt
Honda Civic (2001 - 2005)
Jun 26, 2018 12:28 PM
romeo_f
Apr 7, 2011 10:44 PM
Nataku
Jan 21, 2007 10:38 AM
sirrjibbalott
Feb 18, 2006 11:52 AM
brixity
Apr 10, 2005 08:17 PM
