High impedance injector for d16a9
I want to remove the low impedance injectors (with resistance box) I want to put high impedance and I take off The Resistance Box it Is for a d16a9 engine but I do not know which reference to look for.. Any advice?
Im thinking to obd1
Thanks
Im thinking to obd1
Thanks
Assuming the D16A9 uses the same injector as the A6 (235cc), then an injector from the next generation Civic (92-95) has the same output, and the injector in the D16Y8 from 96-00 is nearly the same (240cc). The D16Y7 injector is lower (180cc), that one would not be ideal.
http://www.phearable.net/information...ctorsizes.html
Ok Thanks i will check them
do you know where i can buy a Fuel Injector connector im loking for ebay amazon but the obd1 that i see on picture its obd0
thanks again
thanks again
