Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
B
Old Mar 24, 2019 | 05:06 PM
Fluffer Nutter's Avatar
Default 05 Accord Won't start
Bought 05 accord 2.4l with 260k. The car would start but stuttered at 3000rpm and had codes for both o2 sensors, p0103, and p0498. I replaced the MAF sensor code didn't go away. Replaced terminals because these terminals are very thin and the positive is missing pieces from the bottom of it. When I turn the key on. I can hear the fuel pump prime and it will crank over but not start. Also when I turn the key to on the green key light stays lit for a couple of seconds then goes away. I know that the green key has something to do with the security system. Not sure if it's supposed to go out or stay lit till you start the car. I've ordered both o2 sensors just not here yet.
I went to check out the vapor canister and found a connector with a broken wire this connector has two wires and the wires are blue and white and green and red. Plus found two hoses with holes in them. If anyone can help figure out which connector this is and where I can get the hoses that would be great.
Old Mar 26, 2019 | 01:51 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: B
Connector is for the evap vent shut valve. Hoses can be obtained from dealer, aftermarket, etc.
Old Mar 27, 2019 | 10:25 PM
Default Re: B
I found the hoses but i can't find anywhere that sells the connector.
bLu92bUbbLe
12
Apr 23, 2009 11:02 PM
itrhopeful
29
Jan 16, 2005 03:54 PM
couter.net
Jan 11, 2003 09:10 PM
Turbolude
Aug 25, 2001 08:16 AM
