High Idle
Old Mar 24, 2019 | 10:18 AM
norwood399's Avatar
Default High Idle
Hello folks!! Having one problem with my 93 Honda DelSol 1.6L VTEC. I've installed a Skunk2 70mm throttle body and the car runs like a taped ape!! One problem...I cannot get idle below 2300RPMs...eliminated IACV...obviously no FAST IDLE valve either...turned in idle screw all the way...TPS turned all the way to lowest idle point...adjusted set screw where its letting idle be at lowest w butterfly clo see ed all the way...sprayed either everywhere and no vacuum leaks...WHAT THE HELL...NOTHING???? PLEASE HELP!!!
Old Mar 24, 2019 | 11:59 AM
mk378's Avatar
Default Re: High Idle
The engine can't run without air. It is getting in somewhere. Does the throttle body mate to the manifold properly? Are you using the right gasket?
Old Mar 25, 2019 | 04:07 PM
norwood399's Avatar
Thank you very much for resoonding!! It mates very well and I'm using the gasket Skunk2 sent with it...I'm baffled. I've sprayed everywhere possible w carb cleaner and ether and cannot get a leak response anywhere?? I just dont get it. Just hoping for a magic answer to such an open ended question and problem!! Urrrggg frustrating...Thanks again!!!
Old Mar 25, 2019 | 05:24 PM
K20.ek's Avatar
Any check engine lights??? What are your engine mods?
You have to calibrate your tps sensor if it wasn’t calibrated yet.
Check your map sensor with ohm reader, also it has a rubber o-ring that’s suppose to seal it from air leaks, make sure it’s not broken or slits.
That big of a throttle body your a/f map is probably thrown off too, you need to tune it.
95dc2teg
Sep 11, 2007 05:49 PM
WhoDoYouThink
Mar 28, 2006 04:02 PM
sirshan
Mar 16, 2006 01:32 PM
pouponu
Dec 18, 2005 07:46 PM
B16Hatchcx
Apr 26, 2003 11:40 AM
