6th gen vtec question
Old Mar 19, 2019 | 11:22 PM
2pac1's Avatar
Default 6th gen vtec question
hello
what's the purpose of the pressure switch on the vtec body, and why some cars have a blanking bolt instead of it?
Old Mar 20, 2019 | 08:52 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 6th gen vtec question
Originally Posted by 2pac1
hello
It is to let the ECU or PCM know there is sufficient oil pressure to activate the VTEC solenoid. If there is oil pressure then activating VTEC would allow the engine to rev higher than ~3Krpm, which would cause damage to the engine if the pressure was low.
From what I have seen, US built(USDM) cars have the pressure switch, Japanese built(USDM) cars do not have the pressure switch. Not sure if that is completely true, but that is what I have observed with CD Accords.
Old Mar 25, 2019 | 03:38 PM
2pac1's Avatar
so non vtec cars can't rev higher than 3000 rpm?
Old Mar 25, 2019 | 03:46 PM
shipo's Avatar
That's not what he said.
Tunerguy1989
May 5, 2009 02:54 PM
raidacaipo
May 10, 2008 09:36 PM
B16A1-EF9
Dec 13, 2002 03:51 PM
