Left turn signal intermittently buzzes, before working normally
Had this problem since I got the car, just been putting it off as a minor nuisance and thinking that it would require replacing the switch or something in the column. But now I am wondering if it isn't just an electrical problem.
When I hit the left turn signal, sometimes it will just make a loud buzzing noise for a few seconds, before the turn signal actually comes on. Sometimes I have to switch it on and off a few times for it to start working. The right turn signal has always worked normally. It seems to be worse after the car sits for a while, then with more use it gets a little better.
'91 HF with a lot of hacked up wiring that I've attempted to fix.
i had that problem last year dude but for me it only lasted about two days
then this happend
it also blew the fuse for the brake lights
luckly i had a spare tail light harness so i snipped a new socket from it
and got it hooked up to the one in the car
and so far so good ^_^
then this happend
Haha well mines been doing it for over two years. Think it's a short somewhere in the wiring? Or possibly the ICU?
i think youve just been lucky and your light bulb connector just refuses to die
try removing the bulb and putting a little grease on the contact
it might just fix the buzz
So today the signal was just buzzing and buzzing until I would turn the wheel, then it would kick on. I'll make sure bulbs are good, but also thinking it might be the combination switch if that doesn't work.
ridgeline08
May 29, 2011 10:38 AM
