Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Blow off valve line to intake manifold
Old Mar 19, 2019 | 08:03 AM
Nate254's Avatar
Icon7 Blow off valve line to intake manifold
I have a 2003 Honda Civic LX. I'm trying where the blow off valve (BOV) line connects to my stock intake manifold. Do I need to make a "T" splice? Or do I need to swap my intake manifold to a 96-99
Honda Civic EX? Need help. Thank you.
Old Mar 19, 2019 | 11:36 AM
hondandy's Avatar
Default Re: Blow off valve line to intake manifold
If your car is now turbo charged, and you are running a bov or even a recirculating (bypass) valve, the valve needs to see boost/vacuum to function. So if you let off the gas the throttle body closes, now the lower pressure downstream of the TB lets the bov open and release the higher pressure now between the TB and the turbo. So anywhere you get vacuum is fine. As long as you don't have something else like a check valve or hvac item closing off the source of vacuum (from the intake). It doesn't have to be a big hose or anything. Any little 1/4 vac line under the hood will do, just tee into it.
Old Mar 19, 2019 | 01:10 PM
Nate254's Avatar
Cool. I see one 1/4 hose and it's connected to a 1 psi pressure regulator. This hose is connected to the back of the intake manifold. I'll try to tee on that one. Thanks
Vryantec
Jul 21, 2018 02:36 PM
RiversideS13
11
Jul 21, 2007 08:11 AM
tasco
Aug 30, 2006 02:19 PM
jdmej8gurl
Sep 20, 2005 04:02 PM
93sleeper
Mar 22, 2005 01:50 PM
