GSR TB help
Old Nov 14, 2002 | 07:25 AM
metal-x's Avatar
Default GSR TB help
I need to know exactly what vacums/hose go in here anyone have a diagram I'll apreciate it
Old Nov 14, 2002 | 07:45 AM
jdmcx's Avatar
Default Re: GSR TB help (metal-x)
the two at the bottom are for coolant adn the top one is a vaccume comming out of the charcole canister
hope this helps
Old Nov 14, 2002 | 07:48 AM
Desslok's Avatar
Default Re: GSR TB help (jdmcx)
Ditch the coolant ones. Cooler air.
Old Nov 14, 2002 | 07:57 AM
metal-x's Avatar
Default Re: GSR TB help (sp)
how? cooler is good
Old Nov 14, 2002 | 08:00 AM
Spade's Avatar
how? cooler is good
Just don't hook the line up to the TB.
The line goes from the block to the TB then to the IACV then back into the block. Run one line from Block to block
Old Nov 14, 2002 | 08:02 AM
Katman's Avatar
how? cooler is good
how? easy...just leave those 2 bottom coolant spouts as-is...with no hoses attached to them.
The coolant lines that run to these 2 coolant spouts....just block them off or reroute them so they recirculate coolant. I dont suggest you do this if you live in a snowy climate or way low-temperature climate area though.
Old Nov 14, 2002 | 08:31 AM
mojoGSR92's Avatar
Default Re: GSR TB help (Katman)
I've done this and I live in Ohio where we sometimes see -20 degree weather with windchill. A frozen throttle plate has never been a problem for me, but that doesn't necessarily mean I suggest this for someone else in cold weather. There is supposedly some phenomenon where ice crystals can actually form on the butterfly and cause it to freeze, but I've never had any problems with it.
Just a little FYI...
Old Nov 14, 2002 | 08:37 AM
metal-x's Avatar
Default Re: GSR TB help (mojoGSR92)
up here in toronto it might be a problem, but I may just try it....
Old Nov 14, 2002 | 10:56 AM
MPower332TI's Avatar
Be careful though, cause sometimes when u bypass those hoses ull get a surging idle and it is very annoying..
dropped93ex
Oct 28, 2011 03:59 AM
95CoupeDX
Feb 5, 2008 06:54 AM
lude98SH
Oct 16, 2006 06:28 AM
notstock93
Jan 22, 2004 08:01 PM
Darkteg
Oct 25, 2002 09:00 AM
