Honda CR-V & Element 2WD & 4WD Element & CR-V
Just signed up for a lil advice
Old Mar 14, 2019 | 08:30 PM
Aldo0280's Avatar
Default Just signed up for a lil advice
I just traded a buddys uncle to help him out for an 03 element with the 2.4 & it had a miss & misfire codes for every cylinder so after checking the injectors & coil packs i found that smthen was up with num one cylinder so i thru my compression tester on it & it has lil to no compression in that cylinder basically it will try to build about 20psi then before i can even get back to under the hood it will be back at zero so i pulled the shrader valve out of my compression tester & put some air into the cylinder (at tdc compression stroke) & it seemed to be leaking out the intake but then i pulled the valve cover off & tryed again & now it seems to be leaking out of a few of the other cylinders? I am totally confused & really not sure what is wrong with this thing & could really use some help thank you for any advice you have!
Old Mar 14, 2019 | 08:34 PM
Chrisfrom1986's Avatar
Default Re: Just signed up for a lil advice
Head gasket or warped head.
Old Mar 14, 2019 | 08:59 PM
Aldo0280's Avatar
really? Hmm it doesnt get hot or have water in the oil or oil in the water? it doesnt have exhaust gases comen out the radiator? Or coolant out the tailpipe? & it doesnt use or loose any coolant & when i did the compression test only one cylinder had low compression it doesnt have any signs whatsoever of a head gasket issue just a misfire Issue?
Old Mar 14, 2019 | 09:35 PM
You said you heard it escaping into other cylinders. A fault between 2 cylinders won't mix oil or water. It could also be a bent valve.
JudahDamian
Dec 4, 2018 07:30 PM
eg6_kaydoo
May 23, 2008 09:10 AM
evotux
Nov 20, 2006 07:01 PM
imgonnalie2u
Jan 11, 2005 08:05 AM
