Low fuel light thermistor question
Old Mar 11, 2019 | 09:24 PM
Daniel Landeros's Avatar
Icon6 Low fuel light thermistor question
I have a malfunctioning low fuel light, checked jumping the harness and light does work, does anybody know if the thermistor can be replaced/serviced? I do have a second unit and isn't working either.
Old Jul 26, 2019 | 01:09 PM
Hasan Khurshid's Avatar
Default Re: Low fuel light thermistor question
Have you got any solution yet?
Old Jul 29, 2019 | 02:39 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
How do you know it's malfunctioning? Have you run out of fuel completely? There is a service manual test; it is specific on how the thermistor is to be tested. You have done this?
Old Jul 29, 2019 | 05:31 PM
Yes I have tested the bulb using the instructions and now it is confirm that thermistor is the problem.
But I cannot take out the sending unit. I tried twisting and everything but it doesn't came out.
It's a jdm one.
It can't be straighten more. I tried. Is it the minimum angle it has?
Old Jul 29, 2019 | 08:39 PM
deschlong's Avatar
Loved
Community Favorite
Oh ****, yeah you gotta wiggle it a ton to get it out. Twist and turn a bunch. But it will eventually come. I've done this on an 5th Gen Civic numerous times.
Old Jul 30, 2019 | 07:23 AM
I tried every motion but I can't get it out. Is this the maximun angle? I can't get it straight
Old Aug 1, 2019 | 12:18 PM
BiggieBert's Avatar
Loved
Community Favorite
You don’t pull it out straight, you have to kinda keep twisting it as you bring it out. If i remember correctly it almost comes out upside down. It’s odd, and really only works one particular pattern.
Old Aug 1, 2019 | 12:21 PM
I was searching alot for diy and videos on youtube but I couldn't find. Secondly where I can find the thermistor for low light.
Old Aug 1, 2019 | 12:47 PM
BiggieBert's Avatar
Loved
Community Favorite
This is the USDM part number, should be the same based on your pic, 37800-S04-305
Old Aug 1, 2019 | 12:50 PM
Thanks but I only want to replace the ntc thermistor used for low light.
Old Aug 2, 2019 | 11:44 AM
BiggieBert's Avatar
Loved
Community Favorite
Ohh, idk if You can with how the unit is made. But I guess if you are competent enough with electronics, nothing is impossible. Lol
Old Aug 2, 2019 | 11:48 AM
So yes today it came with little bit of wiggle and only low light thermistor is bad. Other than that the float is working pretty good.
Old Aug 2, 2019 | 11:49 AM
Can you please tag someone who may know which value of thermistor need to be used?
Old Aug 2, 2019 | 12:08 PM
@deschlong
Please can you tell me where I can get the thermistor?
Old Aug 2, 2019 | 12:15 PM
deschlong's Avatar
Loved
Community Favorite
From another low fuel level sensor. Like, any.
Old Aug 2, 2019 | 12:18 PM
If I get the value of the thermistor, then it will be very easy to find the thermistor.
Old Feb 11, 2021 | 03:51 AM
Ahmed Raza's Avatar
I also want to know the value of that thermistor
uhhkilleez
Apr 10, 2012 05:30 PM
dlbazini
Apr 4, 2009 03:21 PM
SoullessJapaneseMachine
12
Dec 8, 2007 05:47 PM
tkevin07
Apr 5, 2006 05:24 PM
rsx03
Aug 18, 2003 09:02 PM
