crank no start, 95 accord
so i just put a new engine in my accord and i started it up and it ran fine,
it was throwing a code 6 (engine coolant temperature sensor) but the next day
it just cranks doesnt even sputter for a sec. i put starting fluid in the throttle body and it started up for
just a second then died, im getting fuel to my fuel rail, and spark but i just cant figure it out,
any help appreciated thanks
Check the main relay. resolder the leads to the board it goes to. the injector resistor box being loose also contributes to no start but a cranking engine
Check the relay. Then check the ECU under the carpet on the passenger side. If when you open the lid on it, you smell seafood or see black tar leaking from the Capacitors, it means the caps are dead.
