1995 Delsol A/T - Key won't turn to 0 position
Old Mar 5, 2019 | 12:02 PM
nicknoble's Avatar
Default 1995 Delsol A/T - Key won't turn to 0 position
Car starts and runs fine. If I shift out of park and back into park, the key will only turn to the 1,2,3 positions (it doesn't push inward at all, like it's locked). If I wiggle the key for a couple of minutes (essentially trying to take it out), it will eventually come out. Unhooking the battery makes the key come out just fine, so I'm assuming it's an electrical problem. I've unhooked the park pin switch, so that isn't what's causing it. I unhooked the ignition switch, and the problem still exists. It doesn't seem to be the brake sensor, because pushing the brakes doesn't make it better or worse. The car does have an aftermarket Viper alarm that I don't use (key fob broke), and that has remote start. Any chance that could be the issue?
If it helps, the issue came with the car a couple of years ago, but has only recently gotten progressively worse.
Old Mar 7, 2019 | 04:39 PM
wurmhole's Avatar
Default Re: 1995 Delsol A/T - Key won't turn to 0 position
wiggle the shifter around when its in park, the (park switch) is going bad
Old Apr 1, 2019 | 01:22 PM
Krauthammer's Avatar
Did you try turning the steering wheel when you turn the key?
slq576
Nov 19, 2013 07:50 PM
aandrewcc
Oct 29, 2009 09:30 PM
95greenlude
Dec 24, 2007 07:01 AM
stichedskater
Honda Civic (2001 - 2005)
Sep 10, 2007 05:22 AM
91hob20hb
Jul 17, 2004 11:16 AM
