94 Honda Accord EX - high beams and dashboard lights
Old Mar 5, 2019 | 07:04 AM
greatbatman111's Avatar
Default 94 Honda Accord EX - high beams and dashboard lights
When I turn on the head light switch - Both high beam lights don't work and no dash board lights either. If the headlight switch is off then the gear position lights do comeback but still no dashboard lights.
I have checked all the fuses both the driver seat side and the one son the engine - all fuses light up with the tester. Also checked both bulbs - they are OK too.
I am thinking about the few possibilities :
- Bad relay fuse
- Bad head light switch , itself.
- Bad dimmer switch
- Bad ground wires / connections
Anyone can provide some suggestions as to how to check/ test for these possible faults and then replace or fix it.
Would greatly appreciate it.
Thank you very much.
greatbatman111
Oct 10, 2019 04:33 AM
boostjunkieee
Dec 12, 2012 05:52 PM
teamWARej1
Nov 22, 2012 07:07 PM
stupidwhitecat
Nov 5, 2005 04:26 AM
