Curious how the steel pads are 'bonded' to aluminum rocker arms
Old Mar 2, 2019 | 04:08 PM
night's Avatar
Default Curious how the steel pads are 'bonded' to aluminum rocker arms
Is this a reproducable thing? To change the pads and sort of cheat the geometry to overcome limits of grinding cams?
I ​​​​​​know cam profiles are a complicated thing, but I feel like it would be worth a try, if possible, to change the pad with a slightly thicker and larger radius. Grinding a cam pushes the contact points with the pad farther out and so reduces the rocker ratio.
The r​​​​ockers on my old 12 valve are a measly 1.35/1.45 so we can barely get any lift in a 2 liter :(
Old Mar 3, 2019 | 08:52 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Curious how the steel pads are 'bonded' to aluminum rocker arms
My guess would be that it is a brazed joint. If brazed, certainly not impossible to remove, but likely impractical.
Old Mar 3, 2019 | 10:19 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Maybe silver brazed, but I don't know if it's strong enough for this application. This is a curious thread, and is sending me down a rabbit hole. Looks like there are some types of AL rockers with steel pads that are pinned, some look like the steel pads are installed into the mold during the AL casting, very interesting.
laur
Sep 3, 2010 07:28 PM
Arsenal
Nov 30, 2006 12:50 PM
nonsense
May 19, 2005 01:30 AM
GRM Scott
Sep 12, 2001 09:40 AM
