How to remove wrist pin from B16 rod and pistons
Just like the topic, I cant figure out how to remove the rod from the piston, stock B16 rod and pistons. Do the wrist pins have to be pressed out, or heated?
tia
tia
i pressed them out with a hydraulic press. they were in there tight!
be careful or you can damage the sides of the pistons when you press them out...
cityofcaterpillars
Engine Machining & Assembly
12
Oct 19, 2016 09:46 PM
