93 Civic EX Idle Surge - Possible Fix
Old Feb 24, 2019 | 11:22 AM
tj4fa's Avatar
Default 93 Civic EX Idle Surge - Possible Fix
Hi, I new here and hope I can maybe help at least some people who have that dreaded idle surging issue.
Bottom Line Up Front (BLUF) - Some people's issue may be caused by a vacuum leak between the Intake manifold and the Power Brake Booster (possibly a leaking brake booster).
Yesterday, while working on my wife's 93 Civic brake system, I pulled the master cylinder to replace it due to weak pedal before and still after bleeding the brakes.
At that time, I removed the brake lines and master cylinder but DID NOT disconnect the vacuum line from the intake manifold to the brake booster.
I started the car up to move it out of the middle of the driveway and immediately encountered the high idle and idle surging issue.
I been researching the internet and numerous possible causes and started troubleshooting.
Since my problem started right after I pulled the master cylinder from the brake booster, I took the vacuum line off the intake port and put a small piece of hose with
a bolt on that port and started the engine (see attached photo below).
Gone was my high idle and idle surging issue with the Civic back to a normal and steady idle.
I hope this helps...
Capped Intake Vacuum Port to Brake Booster - Possible Vacuum Leak in Brake Booster Causing Idle Surge
tj4fa
Feb 26, 2019 06:44 PM
D16Z6racing
16
Aug 12, 2008 11:57 AM
Firescooby
23
Oct 30, 2006 12:07 PM
E-Speed
Oct 22, 2006 10:15 AM
Civd16y8
12
Aug 18, 2005 03:00 PM
