Light and wiper issue
Old Feb 22, 2019 | 10:17 PM
Mrill21's Avatar
Default Light and wiper issue
I have a 98 civic coupe with a b20b4 swap. My issue is the front turn single only work when the lights are off. Also the drivers side is very dim compared to passenger. Also when using the washer fluid the wipers only automatically go when the lights are on but dont when off.
Old Feb 23, 2019 | 05:05 AM
mk378's Avatar
Default Re: Light and wiper issue
This happens when the bulbs aren't grounded. Check the light grounds up front. There's a special piece where several black wires come together and attach to the body, there is one on each side. The washer pump likely also grounds through the left one.
Old Feb 23, 2019 | 05:56 AM
Mrill21's Avatar
I will check that. Do u happen to know where, like behind the headlight housing or in the engine bay? Thanks so much.
Old Feb 23, 2019 | 11:09 AM
mk378's Avatar
They should be attached to the side of the car in the main part of the engine bay, close to the front but visible without taking anything apart.
invader_zim
Mar 28, 2012 09:57 PM
dc2driver408
Aug 15, 2010 07:03 PM
raffydogg
Lighting
Mar 23, 2008 11:53 PM
Metal Typhoon
Oct 17, 2006 05:14 PM
sik_sol
Mar 31, 2005 04:15 PM
