1996 Honda Accord need help!!!
Old Feb 22, 2019 | 06:08 AM
Washburn32's Avatar
Default 1996 Honda Accord need help!!!
My Honda will start up run for while and then it will stalls. I’ll start go inside and go back and it will be off or ill be going down the road and have it stall. It’s will start right back up most of the time, sometimes it takes a minute. After it stalls and running again normal I can drive it for a while again. It’s had the fuel pump, plugs and wire, distributor, main relay all replace. Should I replace the ignition switch?
Old Feb 22, 2019 | 06:58 AM
GhostAccord's Avatar
Default Re: 1996 Honda Accord need help!!!
Is the check engine light on?
have you retrieved any codes form the ECU?
Check and ensure that all of the power and ground connections are clean and tight on the engine, chassis, battery and alternator.
Old Feb 22, 2019 | 11:12 AM
MAD_MIKE's Avatar
MM Gruppe B
Next time it stalls look at the gauges.
If they are all off as well it may be that the ignition switch itself is failing. Fairly common on older Accords ~$30.
With the engine on jiggle the key and see if that affects the running condition of the engine. If you have lots of charms or keys on your keychain this can also affect the ignition switch.
If only the engine dies and the tachometer immediately drops to zero while the other gauges stay functional, then it may be the igniter is failing.
Old Feb 24, 2019 | 10:00 AM
Washburn32's Avatar
Yes the check engine light is on
I have 1 code PO108
Old Feb 24, 2019 | 10:36 AM
Adam Cohen's Avatar
Old Feb 24, 2019 | 10:39 AM
Adam Cohen's Avatar
I think we’re having the same issue. All the same repairs you did. Just bought a new ignition coil to see if it was the issue but no. I’m not getting any power to the coil. The switch is good. Buddy says may be a wire somewhere!
Scoop123
May 27, 2019 08:57 PM
pacdecimal
Jul 4, 2014 05:34 AM
C. Amick
Mar 30, 2011 09:28 AM
fmirkled
Nov 28, 2009 02:52 PM
rustyfan21
Jul 23, 2008 05:41 PM
