what gauge wire for taillight eg civic?
Old Feb 21, 2019 | 02:23 AM
tommy boy2's Avatar
Default what gauge wire for taillight eg civic?
I may need to bridge a bad connector so I need to know what gauge wire is needed, anyone know? I was going to try to crimp on some new spade terminal connectors too, does anyone know the type I need? So many different sizes out there...thanks
Old Feb 21, 2019 | 02:33 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: what gauge wire for taillight eg civic?
usually 22AWG
grab some from the local salvage yard....
Solder, cover with heatshrink tubing. That's the correct way to splice in wire.
Old Feb 21, 2019 | 04:24 AM
tony_2018's Avatar
Fish Twig
dont bridge, cut off the old connector
Old Feb 21, 2019 | 04:56 PM
tommy boy2's Avatar
cut connector out and use butt end splices to reconnect?
Old Feb 21, 2019 | 04:58 PM
mk378's Avatar
Can you find a parts car with the rear harness intact and replace it in one piece?
Cutting off the light side of the connector when it is still good is just a hatchet job.
Old Feb 21, 2019 | 04:59 PM
NVturbo's Avatar
O.G. triple O.G.
DID YOU EVEN READ WHAT I WROTE??
We're nice enough to give you helpful tips and you just want to be selective on what you want to know/read. Self-entitled people these days....
Old Feb 22, 2019 | 04:19 AM
tommy boy2's Avatar
sorry turbo, i didn't see your comment in my fluster, thank you
Old Feb 22, 2019 | 04:20 AM
tommy boy2's Avatar
mk: hatchet job it is, the connectors have issues, one melteda bit and the pin corroded off into the female part, so...
Old Feb 22, 2019 | 08:39 AM
tommy boy2's Avatar
ok, so the lights now work! so far so good. But with my crimp connectors and the replacement connector, they are loose and will rattle around and bounce with each bump. This was clearly hacked before I got the car, and it lasred for year...but I woulfd like to anchor these down a bit more so that there is no movement in the wires and connector, any thoughts? I was wondering about a magnet and a ...? I think on the unbutchered ones the connector slides into a plastic mounting bracket, mine is likely long gone...
thanks again. I promise to read more carefully this time too
Old Feb 23, 2019 | 07:39 AM
JDMdoode's Avatar
I can grab a set of tail light wiring harnesses from the salvage yard if you wanna go that route
Old Feb 23, 2019 | 10:27 AM
spAdam's Avatar
Loved
Community Favorite
^That's the best route.
Old Feb 23, 2019 | 10:44 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Jesus, 22AWG? That's pretty thin. I think you'll find 18 or 16 AWG will be more likely.
Old Feb 23, 2019 | 07:10 PM
tommy boy2's Avatar
it is all wired now just need to shrink wrap the connectors and anchor this tngleweed and the new connector so they don't bounce and rattle...any suggestions? maybe if I just push them all into the hole in the molding it will suffice...they are small wires! no eg civic in the bone yards around here anymore...where have they all gone? that is not good looking forward...
potatostix
Mar 30, 2006 10:02 PM
Voodooboy520
Dec 3, 2005 03:59 PM
C-Zero
May 9, 2004 05:33 AM
mrlegoman
Feb 3, 2003 04:15 PM
StyleTEG
Feb 10, 2002 09:36 PM
