1995 ex d16z6 timing questions
Old Feb 20, 2019 | 07:23 PM
lolopez999's Avatar
Default 1995 ex d16z6 timing questions
Hello everyone this is my first post here, I have a 1995 ex d16z6 1.6vtec sohc and I am a bit confused on the timing. I've read about about timing on this forum and others as well. But my issue is that when I check my timing with the timing light at 16, i get the single line lined up with the cross hairs. The car runs ok just have an issue with oil getting diluted with gas. I thought when checking the timing with the light set at 16 I was supposed to be trying to adjustadj timing with distributor to line up with the middle of the 3 not the single 1 on the crank shaft pulley. So should it be the single or center of the 3? If it's the 3 could this be why I'm getting gas in oil? Only CEL is 43. I was assuming fuel injectors or something related. But now Im not sure about timing. Starts fine as well
Old Feb 20, 2019 | 10:25 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 1995 ex d16z6 timing questions
If your timing light has a "dial-back" **** or buttons to set a digital "advance" value, you set the desired value and shoot for the WHITE (single mark all by itself) TDC line. If you have a "static" timing light, you shoot for the RED (middle mark of the three close together) 16' advance line. You can check yourself with the first style timing light I mentioned... set it for 16' and move the dizzy to line up the WHITE line with the pointer on the lower timing cover... then move it back to ZERO, and the RED line will align with the timing cover pointer.
Old Feb 21, 2019 | 06:02 AM
lolopez999's Avatar
Wow thanks that clarified my confusion, I was un aware of the differences of timing guns. Well it seems I'm set to time, single line perfect at 16 degrees. I'll have to check it at 0 and see if I'm getting the red. I have another question but I'll post on another thread. Thanks again
honda4fun
Jun 11, 2009 04:09 PM
northemt88
Mar 15, 2008 12:57 AM
hondapwr
May 8, 2006 08:17 AM
kholmes
May 24, 2004 07:01 AM
rioninja
Aug 4, 2001 05:48 AM
