Transmission & Drivetrain Gearboxes, Differentials, Clutches
s40 shift fork orientation and bench shifting
Old Feb 20, 2019 | 01:53 PM
Dustinninja's Avatar
Default s40 shift fork orientation and bench shifting
Hey all,
Recently this past month I’ve taken the project of rebuilding my transmission.
Some Background: I’m rebuilding the s40 that came out of a 1999 honda civic dx hatchback
The engine is d16y7 (non vtec) and 1.6L obd II
This is the first time I’ve rebuilt a transmission. I took my trans out when I first bought the car I thought the clutch or something was making a bunch of noise, shortly after I replaced the clutch the noise was less but was still there. It was the input shaft bearing. So, I took out the trans and brought it inside. I started taking it apart, removed the interlock guide bolt and I separated the case half’s, pulled out the main shaft, countershaft, and fork assemblies. Then I replaced the countershaft bearing, main shaft bearing, diff bearings and oil seals. I now have the main shaft, counter shaft, fork assemblies and diff back in and I don’t know how the orientation of the “change piece” goes. In my helms it says “set the change piece” read a little bit further and it says “NOTE: Align the finger of the interlock with the groove in the shift fork shaft.”
What does the alignment look like? They show no pictures.
Also, when do I put the interlock guide bolt back in. Everywhere I read tells me first bolt out last bolt in. But does everything need to be in neutral first? Should It be in second or third gear so the trans closes then put it in? Another thing is everyone says just put it in when its an “empty” hole or has nothing on the left or right of it that would obstruct the bolt.
Lastly, how would I bench shift my trans? I have a screw driver through the nub that the linkage bolts onto but it’s so hard to pull backwards and push forwards, surely it’s gotta be something with the shift forks orientation. Also a side note is that the main shaft does spin freely so there is no binding.
Thanks all to who respond I’m just trying to figure this out
If at all possible if someone have a picture for orientation so I can compare to how my trans looks and go from there.
Old Feb 21, 2019 | 07:34 AM
Default Re: s40 shift fork orientation and bench shifting
I found this photo on a rebuild guide you can barley see what’s going on but it’s just an idea
Old Feb 21, 2019 | 10:55 AM
Another image i found, it's a b series transmission but I assume its the same. Is this the correct orientation?
Old Feb 21, 2019 | 12:53 PM
Aquafina's Avatar
Line the shift fork tabs up and the interlock and interlock guide slot into them, it does not matter how as long as they're all slotted in. The interlock guide bolt goes in last. Look through the hole and make sure the interlock is lined up so you see airspace for the bolt to go into. If there isn't airspace and you see metal, the bolt will hit it, damage it and you'll have shifting issues and gear lockout.
Old Feb 21, 2019 | 01:15 PM
so it doesn't matter if all the gears are in neutral just as long as there's no obstruction for the interlock guide bolt when it goes in. Right?
Old Feb 21, 2019 | 01:59 PM
Aquafina's Avatar
It will be in neutral when its lined up correctly.
Old Feb 21, 2019 | 09:46 PM
Thank you so much i appreciate all of the help and the reply
Dustinninja
Feb 21, 2019 09:45 PM
jdmfreak1992
Honda Civic (2001 - 2005)
Jul 26, 2011 04:52 PM
Uncle Ben's
Jun 2, 2010 09:10 PM
andrewd_89
Feb 10, 2010 04:21 PM
Pbanto
Apr 8, 2009 05:07 AM
