BAD JDM ENGINE SELLER
JDM Engine Virginia
4262 Entre Ct, Ste V
Chantilly, Virginia 20151 Guys this place will rip you off they lie about the compression was told by Mike that it was 240 psi dry cold and when I got it it was 180 psi hot and when I took off the exhaust manifold oil was coming out of the ports were they filled each cyl. with oil to increase pressure to try and trick buyers stay away from this place he sells on eBay and facebooks.
