Bought a suppose to be 97 D15b JDM motor like all them out there and seems to be good. Fist doing swap of wire notices no crank sensor pulled pulley and looks like has mount points on oil pump so should be good there. But while pulling crank pulley noticed have to big chunks broke off pulley so that will not be balanced for sure. So question can I use the pulley from my D16Y7 crank pulley and work or is 1.5 different than the 1.6 motor?
Pretry sure you can use d15 pulley on y7, but the timing marks won't line up. So if you ever go to change timing belt don't go by tdc marks on the pulley. Ran into that bc I have a y7 with a y8 pulley on it, and its not the same tdc marks. In that case you would just find tdc by pulling 1st plug and sticking something down in there while manually rotaging the motor counter clockwise. But like other guy said, line the 2 pullies up and see. I'm pretty sure all d series crank pulleys are the same aside from tdc marks.
i meant use the y7 pulley on d15. I said it backwards. Lol
Sorry was on other projects... But seems like ******* marks are same, but this is what really worried about the weight.. 1.5 is lighter than 1.6 but least .5 lb or so .. so that will throw out 1.5 motor out big time right>? I only got few more days to get money back on this 1.5 JDM and rebuild or something else .. any help asap please.
Admins please post my post with pics I need answer to weight question, if will not work or not, I got to take motor back in today if I want to get my money back...
edit: looks like will not post if pics.. so will use text to explain...
Timing marks seem to line up , but the two are half pound different in weight... Putting .5 pound heaver crank pulley on D15B won't that cause problems with balance?
So looking on ebay for real one there are many light weight ones that fit both D15 and D16 so guess only diff will add slower revers with heaver one. And for think said "Key" Woodruff Key is same so will install should be good right.
Your images have proven that, your next question was a light weight pulley be sufficient. If you haven't read up on why some concerns on these light weight cranks than you obviously need to.
Arg again I want to use the Heaver pulley from the D16y7 which is HEAVER on the motor putting in D15B that has lighter pulley that I showed in pictures!!! come on man your telling me to read and the freaking post tile is
"D16y7 swap to D15b" not other way around............................................ ................. arg so what do I need to read putting on heave to one that was once light mr, 12k post with no answer again!?
Again, crank pulley differences/same already confirmed with pictures. We're passed that and are we are on this in the bold. If you're confused about what you type maybe you shouldn't.
