Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Changing trans fluid at 100k miles
Old Feb 18, 2019 | 04:59 AM
Sean Hanlon's Avatar
Default Changing trans fluid at 100k miles
is it safe to do in this year honda?
Old Feb 18, 2019 | 05:03 AM
shipo's Avatar
Default Re: Changing trans fluid at 100k miles
What year Honda and what kind of transmission?
Why wouldn't it be safe?
Old Feb 23, 2019 | 06:37 PM
Its a 01 honda civic and i hear it causes slipping
Old Feb 23, 2019 | 07:53 PM
shipo's Avatar
Not sure where you heard that, but old ATF is what causes slipping, not fresh fluid. Said another way, such claims are baseless at best and old wive's tales at worst; if you change the ATF and the transmission fails, then the transmission would have failed anyway.
Old Feb 25, 2019 | 07:34 PM
Zigory's Avatar
Id change it fully, the manual says to drain and fill it 3 times while taking the car for a short drive in-between each fill to row through the gears. my dad also said my transmission would go out if I changed my fluid, didn't believe that so I swapped it all and now do a partial change once in a while, it's been fine since 135k to 181k now. I'd recommend using Honda fluid only
Nina M Bullock
Jul 26, 2017 02:42 PM
dumpedcivicej1
Jan 10, 2013 06:07 AM
DennisWaller
Transmission & Drivetrain
Jul 26, 2009 09:41 PM
diamondflaw2005
Honda Civic (2006 - 2015)
Jul 6, 2009 10:33 AM
joekrz
14
May 8, 2007 07:09 AM
