Water in oil?
Old Feb 17, 2019 | 07:03 PM
Justin Branham's Avatar
Default Water in oil?
Hey guys i just changed my head gasket and had the head resurfaced and valves changed on my 2000 prelude h22a4 motor. I drained the oil and water out before i put the reworked head on. Both the radiator and oil pan had a mix of water and oil in them. So after i put everything back on new head gasket and head. I ran the car for a little bit. I still had water in the oil/motor but didnt have any oil in the radiator. Could it just be left over water in the bottom of the oil pan? Or something else?
Old Feb 18, 2019 | 07:05 AM
motoxxxman's Avatar
Default Re: Water in oil?
yes, could just be some that didn't come out.
with fresh oil and filter, drive some more, then do another oil change while the engine is still hot. That should flush it all out.
Old Feb 21, 2019 | 04:15 PM
hey i ran it again and i still had water in my oil. I did a compression test. And they all came back at 150psi. Could my block or head be cracked Or could it be something else?
Old Feb 21, 2019 | 08:13 PM
TimiK's Avatar
10 Year Member
contact the machine shop which did the resurfacing?
did you used oem seals & gaskets?
Old Feb 21, 2019 | 09:08 PM
motoxxxman's Avatar
is it water or is it coolant that is in the oil?
Was it just a little milky? Or did a bunch of actual water/coolant come out before any oil came out?
Old Feb 22, 2019 | 10:54 AM
Coolant.. it was just a little milky.. no coolant came out before the oil did.
Old Feb 22, 2019 | 10:56 AM
i did they said they pressure tested it. And fixed everything wrong with it. And i used a fel-pro head gasket kit.
Old Feb 22, 2019 | 09:03 PM
TimiK's Avatar
10 Year Member
new head studs?
Old Feb 22, 2019 | 09:06 PM
new head studs?
yea put new head studs on. But i think im all good to go. I jacked uo the front end and tried to let everything drain over night. And today i let run for about 20 mins. And the oil came out black with no water in it.
Tonyneedshelp
14
Mar 6, 2012 12:24 PM
mhewitt
Feb 15, 2012 02:07 PM
caminSi
Jul 27, 2006 07:52 AM
MugenFlaredCRX
Oct 20, 2004 03:14 PM
MugenFlaredCRX
Oct 20, 2004 06:29 AM
