Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
1995 Odyssey Distributor part - what is it?
Old Feb 17, 2019 | 04:40 AM
TPersaud's Avatar
Icon5 1995 Odyssey Distributor part - what is it?
The coil pack is on the right and the ICM is at the bottom... but what is the large module in the top left of the distributor? It hugs the spindle for the rotor. The case appears to be cracked and there are signs that there may have been 'tracking' to ground across the plastic casing. Could this have caused a 'no spark' situation?
Also, if I remove the blue/white wire from the ICM, and connect a test light to the (now empty) terminal and crank the engine, I get no signal or voltage indicated. Is this a sign of a faulty ICM? Thanks
KaBlookie
Apr 24, 2007 01:26 PM
benihana881
Jul 21, 2006 10:01 AM
accordselux
Feb 20, 2006 12:25 PM
C-RICKS
Jul 3, 2004 02:06 PM
SI_niki
Jun 15, 2004 07:54 AM
