Eibach Multi Pro R2 Question
Hey guys,
I've been doing some research and I can't find the answer. Am I able to use this Coilovers on a regular non type R integra?
I am searching for some good coilovers for the track and this ones seems to have a great review and they are cheaper than some Jrz.
Thank you
Thank you
Not without using Type R control arms. The rear dampers use a different mount than the other trim levels of the Integra. In order to convert your car to Type R rear suspension, you need to get the rear lower arms and rear ABS sensor lines from a Type R.
Hmm it doesnt sound to be too much of a mission.. I'm gonna put some thought and see if its worth doing that or just getting something that just bolts right on
Thank you
Thank you
To save you a little bit of time....if you are planning on buying them new, they are out of stock at the moment. I was told they are not planning on making more in the immediate future and are focused on ramping up their product production of off road product applications.
Hey Guys,
I can help clarify this.
Part# 4020.713 is Type R Specific (designed for ITR rear lower control arms)
Part# 4017.713 is the non Type R style lower arms.
As of right now, both are out of stock with no plans to remake. Your best bet is look for a used set using the part#'s above. They can still be serviced at Eibach though.
Really now?
Go ahead, you dig up up files off of YOUR shock dyno of this damper...
Eibach makes great springs, but this was one of their products that fell flat on the design side of things. Not to mention the cavitation issues with their remote reservoirs...
If you want to talk suspension, there are three dudes you should be familiar with. Angelo Zarra - Anze Suspension, Paul Yaw - Injector Dynamics, and Tom Glazemakers - Tractive Suspension.
How about instead of making a useless post, you go and talk to the engineers at Eibach to get your shitty product back?
Or, wow, maybe we talk like adults about better alternatives...
Really now?
Jarrett, I did explain both the damping curves and cavitation issues with the remote reservoirs from the Eibach are ****.
As did I list alternatives: Anze Suspension carries Penske, Ohlins, etc that Angelo himself revalves to your usage, as well as Tractive Suspension has the AST Lineup which already have a direct bolt-on configuration.
Spoon Fed much?!
You didn't explain anything, you named two issues with no proof or explanation. You also didn't state the alternatives, you named people and the companies they work for and made it sound like everyone needs to be well read on them to discuss suspension.
My posts don't need to be useful, I'm not the one that is claiming a product has issues with no evidence or further discussion.
Why post at all if you're not going to be useful?
So you are correct, that those individuals are great resources for suspension development.
But you're pretty far off the mark that a random guy on the forums can just call all of these guys up and start talking about chassis setup. So before you come on here scathing everyone with your **** & vinegar response(s), chill out and make sure the resources you're recommending are actual usable by the group you're recommending them to.
One of these individuals is local to me. He is very knowledgeable about suspension setup and has spent quite a bit of time helping one of his employees with his suspension development on the employee's car for NASA time trials. We (the other Honda guys in TT and race group) have all asked him if his boss would be willing to craft a similar package or assist with suspension development for a price. (we're not expecting him to just hand out his time and expertise for free). The answer was a quick, "No". He's busy running a very successful company and did it as a favor to an employee that has put in some hours at said company. Totally understandable position. No tears in our beer.
But you're pretty far off the mark that a random guy on the forums can just call all of these guys up and start talking about chassis setup. So before you come on here scalding everyone with your **** & vinegar response(s), chill out and make sure the resources you're recommending are actual usable by the group you're recommending them to.
That being said, I came here for a discussion on future product design.
What I do on a day to day basis is test products past their limits in the mountains. What I have seen from THIS product is not something to cry or lose sleep over.
Our current double adjustable options for the various Double Wishbone Honda chassis are from AKMEE Engineering (which I'll have a set to test with), Koni Race 8041s, Penskes from Angelo, KW V3s (going on my daily driver this month), or AST 5200s from Tom.
**** and Vinegar? Dude, get over it. All I said was that this product wasn't that good to begin with, so don't cry over it's lack of availability. ****, if you hadn't noticed, ALL suspension is now built to order for the last few years. It's not the 2000s anymore where everyone and their mom is running a set of coilovers and they build the **** in bulk.
Anyways, we're in the Road Racing forum, so let's stick to helping others go fast(er), yeah?
Cheers.
I'm done. The logic of whining over something that wasn't good and isn't being made anymore is below me. I've been constructive and helpful to suggest other options and every time none of you seem to get the point. Over it. Best of luck to whoever reads this 5+ years down the line.
You'll be here for another 30yrs.
Another useless, tactless post.
I'll update everyone on here with results from AKMEE Double Adjustables and KW V3 Double Adjustables. In the meantime, you can always check out the long stroke Koni 2812s and have them valved to your liking. They need more low speed compression for harsher roads to 'float' you over the potholes and bumps effectively. A digressive blow off is fine on rebound.
Koni 2812: HERE
General Koni Information: HERE
Cheers.
Koni 2812: HERE
Cheers.
Last edited by ShaunRR; Apr 4, 2019 at 06:19 AM. Reason: OT accusation removed to keep thread on topic
- Low speed compression won't help you float over potholes and bumps. Low speed compression is for damping smooth suspension movements, like when your car rolls during turn in. If you want to reduce harness over potholes, you want to turn down high speed compression.
- A digressive blow off describes the mechanism that allows a suspension damper to produce a highly digressive curve while keeping the high speed damping from skyrocketing. It doesn't define how it's valved nor will that alone give you any indication whether it will work well on rough surfaces.
- You're using Koni 28 series shocks on the street? The bodies and seals aren't designed for the kind of abuse you get on normal roads. They'll start falling apart within a few thousand miles if you drove them over potholes and over harsh roads. 28 series shocks are lightweight race shocks. You have to treat them a little nicer than that.
Wait. There's a few weird things about what you've said here.
You're right, a 8211 DA or similar Steel Body would be smarter to run on the street. The majority of companies doing Circle Track based suspension on muscle cars, cruisers, etc are almost all Aluminum though, so I don't deem it as absolutely necessary. Varishock, Viking, QA1, Ridetech, etc, and all of those cars running them are substantially heavier than a little Honda. You do bring up a good point with durability, which I relate more with heat dissipation (aluminum can take the damping energy away faster than steel), which should effect seal lifespan. Then you really have to consider the fact that steel deflects less vs. aluminum and that not all damper manufacturers test an ideal wall thickness for different damping rates. In fact, I don't know of a single one that alters it for higher rates...makes you wonder. It's a balancing act of heat dissipation and minimal deflection.
I disagree with you on Low Speed Compression NOT helping on a rough street situation. During an abrupt stroke (high speed), the compression forces being higher than rebound forces at initial movement jack the car up (float) vs. jamming you into the bumpstops (excessive rebound vs. compression), and as such smooths the transition. When this effect really comes into play is something like a washboarded lane on the interstate where the car seemingly levels out (sometimes higher than ride height).
I simply stated that a digressive blow off is going to be a nice starting point. Sure, some could do linear, but Position vs. Velocity is really only the basic-bitch way of identifying a damper characteristic. What we're really after is something with low initial forces to activate and hysteresis that isn't loopy and huge. Cavitation comes into effect on my applications where I'm out driving hard for 4+hrs vs. someone going down a drag strip for 10 seconds.
Cheers.
This forum is just about (almost) useless. haters gonna hate. As an example, recently I brought back a really old post about rod design discussion. I beam vs. H vs. X. It gets locked for no reason other than bringing back an old top topic from the dead. What's wrong with updating an old thread? Nothing but lame *** mods with nothing better to do. No wonder this place is dead. Most have moved on to social media platforms. I make a good post and I get 20-30k views easy there despite only have just over 2000 fans on my page (was only a 3 digits not long ago).
