un- tapped vtec head does it suppose to look like this?
Old Feb 12, 2019 | 08:19 AM
xlonelydrifterx's Avatar
Default un- tapped vtec head does it suppose to look like this?
The head was on an LSVtec setup and I am putting the head back on to a gsr block.
I pull the tap out and wanting to verify if it looks rights in the pic.
thank you for the help
Old Feb 12, 2019 | 10:11 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: un- tapped vtec head does it suppose to look like this?
Looks OK from those pics... blow compressed air into that hole with the VTEC assembly removed and see if you get high pressure flow through the hole in the middle of the VTEC mounting surface. If so, you are good.
PushnFords
Honda Civic (2001 - 2005)
Jan 10, 2018 09:58 PM
BlueByYou
Feb 17, 2010 07:20 PM
LS94tegra
Sep 17, 2008 07:23 PM
g-ride-si
13
Sep 11, 2006 01:27 PM
civickiller
Aug 10, 2004 05:04 AM
