red hot catalytic convertor, smoking
Old Nov 14, 2002 | 12:04 AM
rasta420's Avatar
Default red hot catalytic convertor, smoking
finally figured out the problem with my friends uncles 88 civic dx hatchback - it was the igniter, and we replaced it today. car started, and after about 5 minutes of running, the catalytic convertor started smoking from the inside of the cat, and it smelled nasty, worse than rubber. the cat had also turned red-hot like the exhaust fumes werent going through the cat.
anyone have any idea what this could be?
Old Nov 14, 2002 | 12:53 AM
NUISANCE's Avatar
Default Re: red hot catalytic convertor, smoking (rasta420)
It is most likely clogged. I wouldn't run the car until you fix it, you might f*&k it up.
[Modified by NUISANCE, 9:53 AM 11/14/2002]
Old Nov 14, 2002 | 08:49 AM
rasta420's Avatar
Default Re: red hot catalytic convertor, smoking (NUISANCE)
it wasnt doing it before, how did it get clogged all of a sudden?
anyone else?
Old Nov 14, 2002 | 08:52 AM
89 CRX SI's Avatar
It probly just did tho. Wait for it to cool take it ff. Put on end in a garbage bag and take a poll inthe other end and hammer out all the insides. Then put it back on. Start it up should be fine then go get a high flow cat this week
Old Nov 14, 2002 | 09:32 AM
Drumwurks's Avatar
Default Re: red hot catalytic convertor, smoking (89 CRX SI)
Just be careful if you're running the car like that... I was running mine hot hot hot one night last august. (100-110mph highway runs for almost 40 mins) I pulled off the ramp, and stopped at a light... my car was idling all fucked up. I tried to pull it ahead, it died... I tried to restart it... it started smoking...
Long story short it became so hot my undercoating caught fire, and set most of my engine bay on fire.
Almost lost the whole car, but thankfully it was just a bunch of wiring and vacuum lines, brake lines, fuel lines (cringe), etc etc...
Old Nov 14, 2002 | 09:36 AM
racerxadam's Avatar
Don't let anyone catch you doing that. Its a 10000 dollar fine.
Old Nov 14, 2002 | 10:45 AM
andrew dc's Avatar
Default Re: red hot catalytic convertor, smoking (racerxadam)
cat is clogged or back firing.. could be running real rich? check the timing again
Old Nov 14, 2002 | 03:14 PM
89 CRX SI's Avatar
Not in Canada
Old Nov 14, 2002 | 03:28 PM
primoEF's Avatar
Not in Canada
Yep, everything one is running straight pipes, hehehe
Old Nov 15, 2002 | 01:55 PM
Drumwurks's Avatar
Default Re: red hot catalytic convertor, smoking (EFDog)
Straight Pipes are toally the way to go... Just too LOUD.
But that little T-25 in my garage should help that a bit.
Can't wait till spring.
journeyquest
Apr 3, 2011 07:28 PM
NA JDM GSR
May 24, 2006 07:52 AM
Mrob91GS
Apr 30, 2005 08:49 PM
JoseCuervo
Aug 9, 2004 02:57 AM
sporkcrx
Oct 6, 2003 09:15 PM
