brake upgrade: the actually difference from dx:ex spindle
Old Feb 11, 2019 | 10:52 PM
digitaltoad's Avatar
Default brake upgrade: the actual difference from dx:ex spindle
Trying to understand the actual difference from the dx to ex spindle for a brake upgrade.
I want to build a oem big brake setup on my 2000 lx/abs and drop off the spindle for the shop to install...
can't seem to find why the dx/lx and ex are different, is it the mounting of the caliper, the thickness of the brake mount?
Old Feb 12, 2019 | 07:48 AM
hybridnorth's Avatar
Default Re: brake upgrade: the actually difference from dx:ex spindle
dx/lx are setup for the small caliper/rotor ex/si is for the larger caliper/rotor and you can adapt integra, ITR, CTR, NSX, S2000 calipers with zero modifications to mild modifications. There is also a brake/suspension forum I suggest searching.
Old Feb 12, 2019 | 05:43 PM
94EG8's Avatar
Seagull Management
The biggest difference is the location of the caliper mounting ears. An EX/Si/Integra caliper won't bolt up to a CX/DX/non-abs LX knuckle
Flash202
Mar 6, 2006 05:15 PM
redsled00
Dec 30, 2004 10:38 AM
pburke23
Jun 5, 2004 01:29 AM
Mr_Bojangles
May 18, 2004 03:27 PM
