Doors not unlocking
Old Feb 7, 2019 | 02:35 PM
RicerBoi16's Avatar
Default Doors not unlocking
It got cold outside and started snowing and both of my doors are stuck on lock, I had to go through the trunk to be able in get inside and inside the levers won't go to unlock, it has power locks and it's a 99 coupe ex, even the key won't do anything, give me some pointers please thanks 👌
Old Feb 8, 2019 | 08:24 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Doors not unlocking
door lock rods are likely frozen
Old Feb 8, 2019 | 11:31 AM
BiggieBert's Avatar
Loved
Community Favorite
could the actuator freeze as well? Op get the car to opperating temp and blast the heat inside, get it as hot as possible see if it works? On cold morning, my driver lock is a little harder to “pop” but once the car is warm and dribem a bit it goes back to normal a 92 civic eith power locks.
Old Feb 8, 2019 | 11:42 AM
NVturbo's Avatar
O.G. triple O.G.
I'm sure it can but the door lock rods will likely freeze before the actuator since it's metal while the other is plastic.
Old Feb 8, 2019 | 12:30 PM
BiggieBert's Avatar
Loved
Community Favorite
lol yea that makes sense!
Old Feb 8, 2019 | 04:13 PM
RicerBoi16's Avatar
Yeah it not stuck anymore, I'll see what I can do so it don't that again, thanks guys
Old Feb 9, 2019 | 06:44 AM
NVturbo's Avatar
O.G. triple O.G.
remove the door panels to see if the "plastic" liner is still there. If it's missing, you can recover the area with thick plastic sheeting. The liner helps insulate the door....to a point.
v8killaz
Jan 2, 2015 05:51 AM
abdulmo86
Jan 4, 2009 06:47 PM
Vindicator9000
Sep 17, 2007 11:10 AM
Setsuna F Seiei
10
Apr 29, 2004 07:42 PM
HondaVtec139
Jul 7, 2002 12:05 PM
