95 honda civic wont start
Old Feb 6, 2019 | 04:17 AM
Ken Sears's Avatar
Default 95 honda civic wont start
Have a 95 honda civic lx with a 1.5 liter. Car started up fine drove about a mile started going up a hill and the car started bucking, went to give more gas and the car died and wont start up, any insight on what to look for would be helpful im clueless right
Old Feb 6, 2019 | 06:15 AM
CFiannotti's Avatar
Default Re: 95 honda civic wont start
Does it turn over? Do you have spark? Check under hood fuses. How old is your battery?
Old Feb 6, 2019 | 08:31 AM
Miikka85's Avatar
5 Year Member
How much did you had fuel in the fuel tank? Almost empty fuel tank can cause a problems when driving to the uphill.
Old Feb 6, 2019 | 08:48 AM
Ken Sears's Avatar
i have half of tank
Old Feb 6, 2019 | 08:51 AM
Ken Sears's Avatar
it just cranks no sound like its fireing at all and its a brand new battery
Old Feb 6, 2019 | 03:05 PM
mk378's Avatar
Check the ECU for codes. The slightly more likely reasons for sudden sputter and die on the road include skipped timing belt, blown coil, bad distributor sensor, and rotor melted and/or fell off.
If it's not one of those, then go through the whole standard "it cranks but won't start" troubleshooting drill from scratch, since that is what it does.
Old Feb 8, 2019 | 10:07 AM
09chaplak's Avatar
Loves Tossing Salad
GROUNDS!!!
Old Feb 8, 2019 | 03:47 PM
CFiannotti's Avatar
"While you were driving". I had my previous D15b7 croak at a stoplight,in 2016.Wound up being the distributor internals. If you haven't yet, open the oil filler cap, and crank, to see if the camshaft / valves move. It might be a snapped timingbelt,or if not the distributor could be suspect (check for spark)
dcalloway619
Jul 5, 2014 11:00 AM
offshore
Aug 23, 2011 12:02 PM
laloquera916
Sep 23, 2010 08:08 PM
yahboyryan
Mar 17, 2008 05:41 PM
Pure_Lude
Aug 11, 2007 11:38 AM
