Sunroof Help!
Hello everyone, I have a 95 sedan with a sunroof and I believe the driver side drain is fine but the passenger side is draining straight into the floorboard! Has anyone dealt with this or possibly know how I can fix it? Would it be an option to block it off and just use the driver side drain? Thanks for any help.
Above is recommended. I also suggest feeling around in the passenger footwell for the tube as it is possible it is no longer draining to the outside.
I will definitely do that. I did take a 4 foot piece of wire and fed from the top side till there was only about 2 inches left and went searching for it and there it was, in the floorboard. Did the same on the driver side and got to a point where it wouldn't go any further and couldn't see it anywhere. But I appreciate the help and will let you know what I find
I don't think its in the fender because it runs inside the pillar. You might have to remove the dash to get access to where the other end is though.
For my sisters db7 I had to get extra clear line from the hardware store, I try to get the same ID, and a fitting to extend the inner tube a bit. It wasn't long so to fix it this is what I did. It now has some slack and I don't have to worry about it falling out again.
I will be looking into the issue today, but I was wondering if anybody knows where to get the replacement trim that goes around the windshield? Had the windshield replaced cause it was originally thought to be the culprit and the trim pieces are no good
^^^ I just found that out. I pulled the glove box out and the trim piece on the pillar and you can't see anything. Might could pull down the whole piece where the blower motor is and maybe then. I really hope the dash doesn't have to come out but it ruined my carpet and the z6 started knocking and I'm in the planning stage of doing a kswap instead of rebuilding so I guess I have plenty of time to find a fix.😒
cilvia
Paint and Body
Jul 18, 2007 12:45 PM
