Oil dilemma - what types should I use or avoid for my purpose?
Old Feb 1, 2019 | 10:26 AM
Gianlukito's Avatar
Default Oil dilemma - what types should I use or avoid for my purpose?
Hi guys, I have to change oil to my eg6 with engine b18c rebuilt with Wiseco pistons, the rest is all stock. Now the engine is 5000km and has always been used with Motul 300V 10W40 oil. Reading and listening to various tips, not yet understood what is the best solution and I look for your advice here.
The car is only used on weekends for pleasure trips, and 6/7 times a year I participate in trackday. Environmental temperatures of use from 5 degrees to 30/32. The engine has a 19-row Mocal oil radiator and even on the track the oil temperature never exceeds 110 degrees in summer.
I think I have provided all the information for your noble advice
Old Feb 1, 2019 | 11:11 AM
TheShodan's Avatar
Moderator
Default re: Oil dilemma - what types should I use or avoid for my purpose?
I've read this several times now, and i guess I'm looking for a question to help assist you on, if any. What is your basic question, here?
Old Feb 1, 2019 | 12:46 PM
Gianlukito's Avatar
Which oil for b18 for road/track use?
Old Feb 2, 2019 | 09:50 PM
TheShodan's Avatar
Moderator
This is not a valid question. Road = road race/circuit or street/daily use . What do you mean by "track"? What type of racing age toy trying to involve yourself with?
There are many different oils to us. Best ones need a high ZDDP (zinc) content. Brands NOT to use are Mobil 1 Synthetic, in any weight.
You can use anything from Castrol Edge, to Pennzoil, to Brad Penn, etc.
We can't read minds. But this is the last attempt to humor you. There are literally 15years of archives here you can plow through to understand your needs. But there is no BEST he, only what is best for you.
Old Feb 3, 2019 | 07:52 AM
2x0's Avatar
2x0
10 Year Member
Default Re: Oil dilemma - what types should I use or avoid for my purpose?
What's wrong with it?
Old Feb 3, 2019 | 10:33 AM
Gianlukito's Avatar
I had written it in the opening topic: The car is only used on weekends for pleasure trips, and 6/7 times a year I participate in trackday.
Now i use Motul 300V 10x40
Old Feb 3, 2019 | 11:16 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Why are you using 10W40?
Pick any modern name brand synthetic oil in 0W or 5W 30 and call it a day.....
Old Feb 3, 2019 | 01:14 PM
Gianlukito's Avatar
thanks for the advice, I would like to understand why; is not the gradation for my climate too low? Here in Italy many people use and recommend 15w50 and I would like to understand the motivations of such advice.
Old Feb 3, 2019 | 02:28 PM
TheShodan's Avatar
Moderator
You'll find more information here through their forums.
Bob Is The Oil Guy
Old Feb 4, 2019 | 07:29 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
The engine was designed around 5W30(which is suitable for all climates/temperatures)
If the engine is modified/raced, then use a synthetic version of 5W30. Or a racing only version. There is no valid reason to change the weight at this point.
The majority of people who run thicker oil, do so out of shear ignorance and misunderstanding of Tribology.
Old Feb 4, 2019 | 10:36 AM
2x0's Avatar
2x0
10 Year Member
I think that thicker oil is used because in racing applications, especially forced induction an oil-cooled turbo can increase oil temps quite a bit.
Would really like to know why Mobil 1 should not be used, as I was just about to put in their 0w-50 racing oil....
Old Feb 4, 2019 | 05:40 PM
TheShodan's Avatar
Moderator
Thicker is not always better, as some oils actually burn off MORE as cover temperatures increase. That's why many circuit cars actually use a 0w oil because the car almost never runs comes in racing conditions. (See Enos Racing Oils as an example). Bearing clearances tend to be optimzed towards those thinner oils
Mobile Synthetic tends to run almost too thin. So thin, that I've seen oil weeping from between the head gasket and block (by the VTEC solenoid). Then when changed to something else, like a Castrol or Brad Penn, that weeping actually goes away. I kid you not.
Old Feb 4, 2019 | 05:55 PM
2x0's Avatar
2x0
10 Year Member
Mobile Synthetic trends to run almost too thin. So thin, that I've seen oil weeping from between the head gasket and block (by the VTEC solenoid). Then when changed to something else, like a Castrol or Brad Penn, that weeping actually goes away. I kid you not.
What would you recommend as an alternative to the Mobil 0w-50 then?
Valvoline VR1 looks good, but it only comes in 10w30 and 20w50. Not sure what either of those changes in weight might affect.
Old Feb 4, 2019 | 06:28 PM
TheShodan's Avatar
Moderator
I tend to go with what's best for the turbo. As something that rotates 20,000 times faster than the engine itself takes precedent.
Valvoline VR1 "blue" 10w30 is just fine
Old Feb 5, 2019 | 10:55 AM
aw614's Avatar
10 Year Member
Loved
I recall 40 weight oil being more popular over on ek9.org vs on the north american forums I have read...
Old Feb 5, 2019 | 12:04 PM
TheShodan's Avatar
Moderator
That's more based upon availability than popularity. A 40w is just not that in demand in the U.S. for off-the-shelf oils.
The specialty brands like Brad Penn, Eneos, , VR-1 and Rotella T5 & T6 oils are more in demand for 40w in the U.S.
Old Feb 5, 2019 | 03:18 PM
tony_2018's Avatar
Fish Twig
Interesting, under what conditions does this happen?
Old Feb 5, 2019 | 10:15 PM
TheShodan's Avatar
Moderator
Normal operating conditions. No racing, nothing fancy
Old Feb 6, 2019 | 03:49 AM
2x0's Avatar
2x0
10 Year Member
I have been using Mobil 1 in all of my cars for 15+ years now. They all do leak, but they're all old cars too
Definitely going to try switching to Valvoline or Castrol and see if it makes a difference. Ordered VR1 for the CRX.
Old Feb 6, 2019 | 08:37 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Right.
Well my post above specifically addresses the reason for this fallacy....
There is no reason other than personal preference or experience.
Ive found that Mobil-1 tends to burn/flash off much more quicker than other synthetics. I change my oil every 7k. Have for the last 15 years. With mobile 1 I was always 1 quart to 1.5 quarts low at the end of my OCI. With other oils(specifically Pennzoil Platinum) I usually lost no more than .5-.75 quarts. So I dont use Mobil-1
However it is factory fill in many high horsepower production vehicles.
gtimax
Jun 5, 2020 05:28 PM
gizzmo222
Aug 14, 2018 07:08 AM
yujayn
Honda Civic (2006 - 2015)
64
Jan 8, 2015 09:24 AM
RedlineMotive
Performance
Nov 6, 2010 11:07 AM
turbodailydan
Jul 14, 2009 06:15 PM
