JDM H22A Camshaft position sensor
Old Feb 1, 2019 | 01:12 AM
EpochZ's Avatar
Default JDM H22A Camshaft position sensor
So I'm haveing trouble finding where the sensor is located. I called honda the dealership and they cant help me and told me to scrap the car they trippen. Its not inside of the distributor and its not in the usual spot cars have them at. Anyone help?
Old Feb 1, 2019 | 09:10 AM
snobordboy's Avatar
Moderator
Default Re: JDM H22A Camshaft position sensor
There isn't one....
Old Feb 1, 2019 | 10:41 AM
EpochZ's Avatar
They why is my car reading as a code top dead center sensor?
Old Feb 1, 2019 | 11:04 AM
PreludeJunkie91's Avatar
https://honda-tech.com/forums/honda-prelude-4/code-8-top-dead-center-sensor-1764535/
Should help
Old Feb 1, 2019 | 02:15 PM
snobordboy's Avatar
Moderator
The car does have a CRANK position sensor. On the jdm cars it should be in the distributor, on the us H22A4 it is down on the oil pump.
Old Feb 1, 2019 | 09:12 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
OP stated he has a TDC code. Either way, the JDM H22A distributor has all three sensors (TDC, CYP, and CKP) inside the distributor housing
Old Feb 4, 2019 | 04:30 AM
TimiK's Avatar
10 Year Member
ICM (ignition control module) probably bad inside distributor
hondaclown
Jul 17, 2023 08:14 AM
SIDreamer
May 2, 2011 09:51 AM
Holistic28
Honda CR-V & Element
Apr 4, 2011 09:52 AM
wdmcgee
Mar 29, 2011 09:30 PM
YellowR2000x2
Mar 4, 2005 04:29 PM
