EG6 Power Folding Mirror Diagram
I have been researching for eg6 power folding mirror diagram but I keep getting the diagram for an ek9. I also searched on HT forum and can not locate one. Anyone have one available or know where i can find a diagram? Thanks!
Your method is for complete power window and door lock swap. I am not doing all that. I just need to do the power mirror conversion. Your mirror comes heated. I only have power folding only. So the wiring pinout is different as well.
No.
Figure 6 shows the wiring diagram exactly as you need. Just ignore all the "heated" aspect to it. All other wire placement related to the power folding feature is the same, starting with the WHT/BLU wire to the power folding relay emerging from C555 pin 9 on the fuse box. And you can go from there.
Click for link to PDF.
Figure 6. PFHM Wiring Diagram for a 92-95 Civic, designed in the
style of Helms diagrams. Click image for a link to a PDF version of this document.
Thanks for the diagram! But is there a simplified version? Apparently the seller didn’t include the pigtails for the mirrors. So I have to modify it somehow or find one
That's as simple as it gets. You will need to poach pigtails from a donor. I think many many nineties Hondas use the same mirror connectors and pins. They are a ******* pain to deal with too, it's best if you have some you can practice on. I think the ECU pins are the same design? But my memory now is weak for these kinds of details.
^Yes. If you have problems finding the OEM pig tails, see if JDMdoode here on the forums can help you. He's helped me and many others out before by scouring for parts in his local yards.
Also, you will be swapping into LHD manual mirror shells, correct? Otherwise be prepared for disappointment due to view angles.
Swapping mirror shells? Can I just swap the mirror alone by itself.
Yes I have the power folding mirrors already. However, I need to wire it up myself since DX doesn’t come equipped with it. But your write up definitely helps. If only I can find some pigtails. I probably hit up a junkyard when the weather settles. Rainy season. ��
I think you need to read through my DIY thoroughly. But at least since you're starting out with manual mirrors you can swap the internals of the power folding ones into them, instead of having to buy the manual mirrors to do the swap.
wad240sx
Jan 23, 2009 12:48 AM
alacard
13
Dec 10, 2007 04:11 PM
TylerC161
Aug 9, 2007 11:15 PM
