Changing out motor mount
Old Jan 28, 2019 | 02:16 PM
Joey Mitchell's Avatar
Default Changing out motor mount
Hi, I was wondering if I could replace the motor mount on the front of my engine (drivers side mount where the timing belt is) with a different mount? My car is a 98 ex, and that motor mount on mine is shot and doesn't even have the center bolt in it that fastens the motor in. I have a 92 ex parts car that has a perfectly good mount there at the timing belt. My concern is that they are 2 totally different types of mounts. Would the mount from the 92 donor car bolt right in or would I have to do some type of fabrication? Or should I just go buy a mount off of a 96-98 just like mine? I do like the looks of the mount from the 92 a lot better. I
Old Jan 28, 2019 | 08:58 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Changing out motor mount
If would be a lot of fabrication to make a 5G mount work in a 6G chassis... but you can buy it as a bolt-in product from HASport. It looks great and fits perfectly.
Old Jan 29, 2019 | 02:25 PM
Ok, thanks for the info will check it out!
fatfurious2
Mar 6, 2009 02:09 PM
bunske123
Oct 10, 2007 10:50 PM
Ninety-9 SE-L
Suspension & Brakes
Apr 17, 2007 01:37 AM
DeeCeeTwo
Jul 19, 2005 11:32 PM
civcexcoupeblack
Oct 2, 2002 05:36 PM
