What to try something with the obd2b
Old Jan 28, 2019 | 09:06 AM
minituner's Avatar
Default What to try something with the obd2b
So I have a 2000 Honda Civic EX coupe I was told and right on the forms that the 96 through 2000 ex models only and that the engine harness wiring harness all other plugs on the diagram to the plugs to the computer are all the same.
this is what I want to try but wanted to know if anyone had tryed doing this to.
So I have a 97 ex engine harrness with a jumper harrness to obd1 an I just picked up a 2000 ex coupe now I know the 2000 ex has obd2b an the last plug that goes into the computer is different then the 98 so because the ex harrness I was told that are identical other then the last plugs that plugs into the computer so I didn't know if I depinned off and switched the plugs around on harnesses if it would work the same as getting a jumper harness
Old Jan 28, 2019 | 09:17 AM
tony_2018's Avatar
Fish Twig
Default Re: What to try something with the obd2b
If you're not comfortable at depinning than I wouldn't try it.
Petnzoo
Feb 27, 2012 11:27 AM
daddycasper97
Apr 26, 2011 11:36 AM
illios
May 18, 2010 02:20 PM
96hatch96
Apr 9, 2007 12:12 PM
hatchpat
Jan 8, 2005 03:39 PM
