Suspension & Brakes Theory, alignment, spring rates....
Skunk2 lowering spring question
Old Jan 27, 2019 | 06:16 AM
Droop408's Avatar
Default Skunk2 lowering spring question
From the amazon page of my actual order.
If I have the master spring I should be ok, but I’m not.
This is how it sits with the wheel on and car on ground. Full weight doesn’t compress it enough.
For my 95 civic EX sedan I ordered S2 sport shocks and springs with part number 519_05_1480 but received 519_05_0005. I didn’t notice it was a different part number till things didn’t want to mesh up. When I tried to assemble them together on the drivers front, I couldn’t get the spring compressed. The spring compressor’s “teeth” from auto zone wouldn’t fit in between the coils so I loosely mounted it up and tried using the weight of the car and it still didn’t compress enough. After some research I found that part number ending in 1480 (part I should have gotten) is the same as the part number I received, that it’s a master spring. Well then what am I doing wrong??? I’ve lowered 4-5 cars in my time, not to mention a full size pickup.
Old Jan 27, 2019 | 06:48 PM
Droop408's Avatar
Default Re: Skunk2 lowering spring question
Never mind. With the help of a friend we got it.
Old Jan 29, 2019 | 03:01 PM
spAdam's Avatar
Loved
Community Favorite
So what did you find? You should close the loop so that other people in the future can find the answer too. "Nevermind" isn't very community oriented.
Old Jan 29, 2019 | 03:25 PM
Chrisfrom1986's Avatar
Correctly using the spring compressor I'm assuming.
Old Jan 29, 2019 | 04:45 PM
spAdam's Avatar
Loved
Community Favorite
Kind of what I remember from using those shocks with H&R race. That makes sense.
Old Jan 29, 2019 | 07:00 PM
Droop408's Avatar
I found that I used all the bumps stops provided (the bottom full sized black one and two orange ones) plus the factory one that goes in the top hat, not allowing enough space to to add washer and nut to be tightened. So I removed one of the orange ones and used the factory black one in top hat because it’s shorter, allowing me to button everything up.
So yes the springs I received, even though it was a different number, did work just fine.
After a few days of usage I feel that the combo works pretty good. I don’t race or track the car, nor do I plan to “stance” it despite the slightly stretched tires. I just wanted something to tighten up the ride.
Old Jan 29, 2019 | 11:52 PM
The instructions should have mentioned having to cut the bump stops to fit.
Old Jan 30, 2019 | 03:15 AM
Droop408's Avatar
Instructions specifically said NOT to cut bump stops or that it would void the warranty. It was weird because the way they came Preassembled, didn’t match up at all to the way the instructions were saying to line them up. Like I said I’ve lowered my 2015 Si, F-150, dodge neon, cutlass supreme, even a Suzuki Swift 🤣but none were as confusing as this civic.
Old Jan 30, 2019 | 06:21 AM
spAdam's Avatar
Loved
Community Favorite
This is confusing. There is only one bump stop per damper. Are you talking about the top hat bushings? The Skunk2 dampers same with poly top hat bushings too. You should not have tried to reuse the factory stuff or cut the Skunk2 bump stops.
Old Jan 30, 2019 | 09:34 AM
Tyson's Avatar
i assume he's talking about the new bumpstop and top hat bushings.
but the thread started pretty damn confusing. i had no idea where he was going with that first pic and then the pic of his shocks totally missing the top hat bushing.
Old Jan 30, 2019 | 10:03 AM
Droop408's Avatar
Ya that’s what it was. Mistake on my part. I miss took the top hat bushing for a bump stop and added the factory top hat bushing back in 🤦. For someone that’s lowered cars before I don’t know how that got by me. Oh well, live and learn. On to my next project.
Thanks for the responses.
Old Jan 30, 2019 | 10:05 AM
Droop408's Avatar
This is how it came out the box, that’s why it threw me off.
Old Feb 1, 2019 | 09:13 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Bump stops for days lol.
Old Feb 1, 2019 | 09:24 AM
It's just the bushings under the bumpstop instead of on top.
Old Feb 1, 2019 | 07:00 PM
Droop408's Avatar
Ya, I didn’t realize one was a bushing and the other was a bump stop.
AMseven
Suspension & Brakes
Dec 14, 2010 08:32 PM
91bluehatch
Suspension & Brakes
Feb 17, 2009 12:56 AM
4door
Suspension & Brakes
Sep 15, 2005 05:06 AM
LBBP R
Dec 29, 2004 09:34 PM
sjracer
10
Apr 16, 2003 12:58 PM
