Transmission & Drivetrain Gearboxes, Differentials, Clutches
Cracked head between collant passages, fixable?
Old Jan 21, 2019 | 10:55 AM
eh2_Trav's Avatar
Default Cracked head between collant passages, fixable?
I pulled this gsr head from a swap I purchased and noticed that is a hairline crack between two coolant passages. It was assembled by a shop so I’m surprised (kinda) that they didn’t tell the guy his head was cracked. Long story short is the head repairable or do I really need to worry about it. I was thinking the repair would be easy to drop a few beads across the crack then get the head milled. I don’t think the hairline crack would really matter and unless you overheat the head it shouldn’t get worse but that’s a complete guess. I never ran a head with a hairline crack like that. Curious to see if anyone ever ran a head with a small crack like this. Thanks for any suggestions or advice.
Old Jan 21, 2019 | 11:00 AM
eh2_Trav's Avatar
Default Re: Cracked head between collant passages, fixable?
And why did I post this in the transmission section ???
eh2_Trav
Welding / Fabrication
Feb 11, 2019 05:42 PM
eh2_Trav
Engine Machining & Assembly
Jan 27, 2019 09:51 AM
butch11a
Jan 3, 2005 07:46 AM
Eg6_JDM
Oct 21, 2002 05:47 PM
