Crx main relay problem
Old Jan 20, 2019 | 11:47 AM
Ale_mata's Avatar
Default Crx main relay problem
Ok guys i have a problem with my engine harnes gnds they are getting power so i check all the grounds even the under dash and the ground from the main relay as soon i plug it in click in but the ground its getting power any ideas whay its doing that i already try with 5 main relays please heeelpppp
Old Jan 20, 2019 | 02:53 PM
arries289's Avatar
Default Re: Crx main relay problem
Your grounds are getting power? You have the battery hooked up wrong or some other major wiring issue.
Old Jan 20, 2019 | 03:25 PM
Ale_mata's Avatar
My battery its correct its just when i plug the relay back i check the ground with the tester and gets power but its just when i plug the relay on
Old Jan 20, 2019 | 06:08 PM
arries289's Avatar
The confusion I am having is grounds don't have any power - current yes but voltage no. So, Im not understanding what you are saying. What is the overall problem - no start?
Old Jan 22, 2019 | 10:18 AM
Ale_mata's Avatar
with relay the ground #2 get power
91_Project
May 22, 2014 07:42 PM
Serdar
Apr 13, 2014 09:34 AM
JAlvarez
23
Feb 9, 2011 10:18 AM
kac3r
Oct 1, 2008 09:32 PM
wetzelman1
Jul 12, 2004 09:15 PM
