2001 accord awd conversion
I was just thinking about coverting to an awd set up on my accord that I have already done a jdm h22a swap in and was trying to get advice on this matter. Any suggestions? My h22 swap
Generally, if you have to ask then it probably is not within your scope.
98-02 USDM Accords are CG bodies.
00-01 JDM AWD Accord SiR Wagons are CL bodies.
Find the diagrams and see how well related the rear suspensions are on the CG vs the CL.
CA-CE Accords are the similar suspension wise with a trailing arm.
CF-CL Accords used a multilink rear suspension.
Look up Bluetop AWD Sir Accord wagons, that will be your go to parts.
Thanks will look at it and see what's up when I get home from work
