ex harness with b16? help
I have a 97 civic dx that I b16a2 swapped, I picked up a obd2a ex harness for my b16a2 and everything plugged in okay except the cfs sensor. the harness has 3 wire plug and my cfs sensor has a 2 wire, what should I do to hook this up? also I cant find the secondary O2 sensor plug. another question I have is there is a 2 wire circular plug that is pretty long and it goes no where. I think it is for the power steering but I have manual steering. am I mistaken? someone help please
I still have to extend vtec wires and 02 but I'll worry about that later I just need to figure out what's going on with this cfs plug and the other random plug I think is for the power steering?
your a hero thank you so much, I think I might have to add the secondary 02 because of inspection, I think it will throw a code then it wont pass unless there is a way around passing inspection without throwing a code for the secondary 02, can you bypass it and trick the computer? will the car run bad with only one 02 sensor?
The secondary O2 sensor is only used to detect catalyst function... it has no bearing on engine function. You can try to use a "fouler" to get the secondary O2 sensor out of the direct exhaust stream... it might work, it might not.
lonely_driver4
Feb 10, 2019 09:13 PM
B18CivicEH2
Sep 10, 2007 07:10 PM
ricodemus
Sep 15, 2002 04:48 PM
