Educational help please!
Old Jan 16, 2019 | 03:58 PM
daniel99em1's Avatar
Default Educational help please!
Hello everyone I have a 99 ex coupe with a 00 b20 , I ran it catless for a good three-four months, Someone warned me I’d burn some valves. Anyways, As I was changing my Header gasket I noticed cylinder 1 having alot of carb around it? Im assuming I have to replace my head gasket as well since It smells funky around the head/ exhaust manifold gaskets area while its on. Would I need a rebuilt head?
Old Jan 16, 2019 | 04:09 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: Educational help please!
The person who told you that is wrong.
Looks like you had an exhaust leak which is why you are replacing your exhaust manifold gasket.
If you are concerned about a bad headgasket then do compression and leakdown tests and report back with the numbers.
Old Jan 16, 2019 | 06:25 PM
DaX's Avatar
DaX
Loved
Community Favorite
Originally Posted by Caoboy
Looks like you had an exhaust leak which is why you are replacing your exhaust manifold gasket.​​​​​
^This. Are all 9 of your exhaust manifold studs present when everything is assembled?
Old Jan 16, 2019 | 06:43 PM
yes all 9 bolts are on , Once I started the car I smelled burnt again like how I was smelling with the exhaust manifold gasket but that’s all replaced now. I didn’t change the head gasket when I did the swap so could it be it going bad now ? Also I need to fix my temp gauge sending unit cause right now it doesnt work and my fan switch was broken so im replacing that also
Old Jan 16, 2019 | 06:59 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
A) are you sure you fixed your exhaust leak? Did you check to see if the header was warped or cracked?
Are there any other exhaust leaks?
B) Are you or have you overheated the car ?
Old Jan 16, 2019 | 07:51 PM
I didnt see if it was warped but it had a small crack on cylinder 4, No it hasn’t overheated before Its drove fine no issues for about 8 months but I cant see where my temp is right now till I fix my temp gauge sending unit. Are head gaskets like that ? Its blown huh since its metal then goes to the blck material?Thats the reason im starting to smell a lil funky scent ?sorry Im new to all this and still learning
Old Jan 17, 2019 | 03:00 AM
DaX's Avatar
DaX
Loved
Community Favorite
A "burnt smell" is not a good way to diagnose a blown head gasket. The best way is a compression test and a leak down test. You can also look for signs of oil and coolant mixing, but a lack of this doesn't rule out a blown head gasket. The black soot all around the #1 exhaust port is from a poor exhaust manifold seal. The only "black" I can see in what you have circled looks like the Viton coating on the top layer of the steel head gasket.
Is the car smoking out of the exhaust?
Does the car have a catalytic converter?
You need to get the fans working before you start driving this. The sending unit for the gauge isn't going to keep the car from running or make it run poorly, but I recommend getting it fixed quickly also.
Old Jan 18, 2019 | 01:38 AM
Replaced my fan switch sensor ,The car does have the cat still and No it hasn’t smoked and Alright I will rent the tool and do a compression test.
Psycho719
Oct 22, 2010 11:23 AM
mattbishop
10
Feb 4, 2006 09:11 PM
yojimboRSX
Mar 23, 2005 04:04 PM
kb798
May 3, 2004 08:40 AM
r0cket247
Jan 6, 2004 08:38 PM
