1994 Honda Civic LX 1.5L hard start in rainy weather
Old Jan 13, 2019 | 06:22 PM
civicali's Avatar
Default 1994 Honda Civic LX 1.5L hard start in rainy weather
We've been having issues with starting a Civic.
Will not start when its raining or after a rain event.
During and after a rain event, check engine light stays on for a very long time (cannot hear the fuel pump priming) and doesn't turn off when turning the ignition (but not trying to start or crank car).
Car starts fine on warm days, with no rain. The check engine light turns on and off when turning ignition and the fuel pump buzzing sound is heard.
We have replaced the spark plugs wires, cap and rotor, fuel filter, and main relay.
All work was due anyway except for the main relay.
Replacing the above parts has not solved problem.
Do we have a problem with the ECM?
Is there a test that can be performed that will point to a bad ECM or a bad connection somewhere.
Again, issue is happening during and after a rain event.
Any advice is greatly appreciated.
Old Jan 14, 2019 | 05:48 AM
scelestus's Avatar
Default Re: 1994 Honda Civic LX 1.5L hard start in rainy weather
This is the 88-91 section, so you're likely to get more help if you're in the right subforum. That said, I think you're overlooking a key point - the "rain event." Do you have a leak anywhere near the ECU? How do those connections look? Are there any CEL codes during a rain event?
civicali
12
May 24, 2019 05:01 PM
Christopher Mai
18
Nov 16, 2016 03:11 PM
bluecoronet
Nov 25, 2010 03:31 PM
lord_old
Jun 1, 2004 05:52 PM
maxxd97
Apr 23, 2004 06:49 AM
