Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Multiple high circuit codes. p0118 p0102 p0113 p2649
Old Jan 13, 2019 | 02:57 PM
Jfrazer22's Avatar
Default Multiple high circuit codes. p0118 p0102 p0113 p2649
2008 honda accord. Installed rebuilt engine. Will not start and have following codes. p0118 p0102 p0113 p2649. The radiator fans come on as soon as I turn on ignition. Engine temp gauge also climbs to hot with ignition on. I checked engine temp, with and without jumper scan tool indicates -40c. I'm not getting voltage to sensor nor a ground reference. With multiple high circuit codes I assume I have a power or ground issue but can not find. I did check engine ground and it's good. Not sure where to go from here.
Old Jan 13, 2019 | 04:17 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Multiple high circuit codes. p0118 p0102 p0113 p2649
  • When you said you checked engine ground, did you check G101?
  • Check Under-hood Fuse No. 17 (15A).
  • Check connectors to the ECM/PCM.
  • Check the battery terminal connection. Also check the battery negative connection on the chassis.
P0102 and P0113 are related to the MAF/IAT combo sensor. Check the connector and sensor.
kevin916sfs
Aug 13, 2019 05:49 PM
hrdsktr1988
Honda Civic (2006 - 2015)
13
Jun 24, 2008 07:32 PM
QuickRexSi21
22
May 29, 2006 12:03 AM
immadathonda
Honda Motorcycles
Jan 12, 2006 06:14 AM
